Gear box oil change
Dave M30TDB
Hereford
C220 AMG Sport Estate 2.1 Diesel 2013
i am thinking of doing my own.
quite handy with spanners, does any one have a how to guide ??
2013 C220 AMG Auto
Dave
James Debuse
Mercedes e320 cdi estate w211
I've been thinking of the same. An indi has quoted 195 plus vat which I think is reasonable. Not that I'd know!!!!!!
steveq
Dublin
2011 Merc S212 E220CDI Estate; Tesla Model 3; 1965 W113 Merc 230SL Pagoda
The ATF, filter, sump bolts, etc. will cost over £100.
To DIY it, you will need a pump to put the new ATF in and and adaptor to connect to the sump. You will also need a low range torque wrench. That is assuming that you have the other items such as ramps, axle stands, sockets, etc.
£195 is a good price but make sure it includes draining the TC.
I agree, make sure its all the fluid. We are closer to 290 if you have stop/start (7g +)
ajlsl600
france
what an unbelievable amount of faff to change gearbox oil .back in the day i could drop a ford escort gearbox on my own in 25 min overhaul it ( i had the limited kit required , dummy layshaft, butane lamp to heat tail housing seal installer and press ) in 45 min and put it back in 35 min time not incl dishwasher style steam cleaner time, assumes pts required ,bearings,needles, thrusts .seals, sincro,s avail.
if i could not do this stuff myself i would be priced out of ownership ,it never ceases to amaze me that £195.00 could seem reasonable for an oil change !! not at all sure this is progress ..unless criteria is from dealer perspective ?
steveq
Dublin
I agree, it is a bit of a palaver, however on the 7G+ it is only required every 75,000 miles or 4 years.
There is a lot of engineering sophistication going on in the gearbox & TC -- so if £250 to £400 every 4 years keeps it working smoothly, it is cheap.
ajlsl600
france
actually i dont think its that sophisticated in itself. the electronics make it so. small oil passages miniature valves ect make it so
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
Hmm I have a 7g+ gearbox and believe the first ATF change is at 31k miles, which I have just attained.
Reading from various sources, 31k,37k 39k 75k and 77.5k miles are mentioned ATF changes on a 7g+ box:confused:.
A definitive answer would be useful.
JBell
Torquey
C350 CDi Estate (GAD Edition)
Sounds right, I paid £200 including the TC and a complete flush
McDonald
Surrey
SL500 2004
Five ATF changes in 77.5K sounds a bit excessive!
AMGeed
Poole, Dorset
No:D. Those were the different intervals I had read had been recommended.
AMGeed
Poole, Dorset
The first oil change for the 7+g/b is 75k miles or 5 years the AMG I believe is sooner which is understandable
Thank you.
So mine is due being a 2014 with 31k miles and an AMG.
Wearsafoxhat
Sunny Hampshire by the sea
E63 :S213, SL500 :R129 , V220
Just to add to the confusion.
Our B class with the 7 speed box is every five years or 45000 miles. MB dealer price was £409.
Luckily, an electrical component within it packed up so we split the bill and had a service thrown in.
Dave M30TDB
Dave M30TDB
Hereford
  • #17
it i could get it for this i wouldnt do myself
MB quoted 500 plus VAT local Indy wanted £400 plus VAT
JBell
Torquey
Both those prices are ridiculous, which indy? maybe a forum member can recommend another one
What about Steve at Avantgarde Mercedes Independent , Clevedon near Bristol
