Deano265
Hi there.
I am at a bit of a loss. Got a 99 CLK w208.
Quick history, Radiator fail so trans/water mix occurred.
Flushed with new fluid, valve plate etc removed and cleaned.
Put back together, trans fluid level checked.
Drive beautifully for approx 10 miles, put trans in reverse to back onto drive and nothing.. no drive in any gear, turn of and on and the car can be moved a few feet at a time. Checked level which looked low so topped up and is now ok.
Started car and initially had a whine from the trans, engaged in all gears but only for a few minutes.
Is it likely that there is a code or something limp mode related stopping it engaging any gears? I am just lost as to how it would be perfect for 10 miles and then nothing..
All help most appreciated, I used this forum to get this far so hopefully someone can help..
