gearbox advice w210
garry01
hi new member in need of advice , this is my 1997 e230 w210
it covered 107,000 miles and genrally drives ok but tends to sometimes lack power, takes a while to register that you have put your foot down, even making a loud bang on the odd ocasion, then it has its good days no problems at all :confused:
has any one else come across this ? or am i on my own !
has had a resent service, changed the compleat exhaust, which leaves me to think its the auto box??
Xtractorfan
S class
most probably a duff MAF or even a blocked cat ..if ya have one.. gearbox tends to play up from other faults,
G
garry01
have replaced the cat & backsystem, whats a MAF?
Stu_CDX
Essex, UK
Mass Air Flow Sensor I think.
Just after the air cleaner box in the engine compartment if it is.
Normally quite a pricey thing, but try plugging it in again. Could be corrosion.
G
garry01
ok thanks , what a plonker i am , only heard of it called an air flow meter before AFM, will give that a try, thanks for the help everyone.
Parrot of Doom
Manchester
If the gearbox fluid hasn't already been changed, it should be done now. There is a DIY in the DIY section if you're confident, but at a Merc indie it isn't an expensive job.
At the very least you should have the gearbox dipped and tested for fluid level.
