the control unit will be behind the passenger kick panel if you pull the carpet forward you will see a metal panel that is bolted with 3 10mm nut pull this panel forward and it is mounted on the back of that
You lost your key ? Or maybe you need a spare!
Your vehicle imobilliser does not respond anymore?
WE CAN FIX THEM ALL !! Mobile !
Save Time and Increase Profits With us !
