Amphiscian
Rather than hijack mr rosher's current thread "rough gears" here's another, similar gearbox question. Car is an '85 W123 230ce and a year or so ago the headgasket was done. Subsequently the gearbox failed to change up without backing right off the throttle, when it would change up, and then on to the same with next gear. Fine, that was sorted, adjustment of a little sliding adjuster on the cable to the 'box. Now just a little reluctant to change down, need fair amount of welly to push it down a gear, otherwise it just hangs on to a higher gear.
But the main problem at the moment (bu$$er, just had a call to say the chainsaw has been knackered. Brand new, well, three months. What do these people have in place of thought.) main problem at the moment is when the engine is hot, putting gearbox into "d" results in a thump and the car lurches, much to alarm of passing pedestrians. If one had granny in the car it would probably result in a small stain on the seat the first few times. And it makes manoevering into those tight parking spots (also subject of current thread) a bit of an unsatisfactorily lurchy business.
It's not the tickover speed, steady at about 600 rpm in drive, 700+ in neutral. I suppose it could be engine/gearbox mounts/drive train flexdiscs/diff (please God no, not the diff) but I would have thought it should slide/slur into gear in a refined manner, not this bang-lurch that seems to be happening. Can't be good for the drivetrain. Gearbox, by the way, got new fluid and filter and otherwise gear changes are absolutely fine; gently slipping from gear to gear. And only done 70,000 miles.
Any comments gratefully received. Would like to sort this out before taking the car abroad.
Now I'll go and sort out the imbecile who shrapnelled my chainsaw...
