Gearbox woes W209 320
jungledave45
CLK 320
Ok so here's the story so far... started up and died immediately a couple of times a few weeks ago for the first time ever, started randomly changing gear all over the place and selecting 5th when slowing down for bends etc. Code came up as MAF ,so replaced that and performed full re-set. Now no longer dies and runs 80% better than before but gear change still seriously clunky and all over the place (box re-set more than once) car has been with independent specialist all day, full diagnostics on everything all values coming back 100% fine. Technician could only advise must be mechanical, torque converter or alike? But unsure. Any help appreciated before I get the gearbox stripped or probably just source a new one.
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
How long ago was the auto gearbox oil changed?
00slk
Cambridgeshire UK
Does the clunky changes only happen until the car is at running temperature?
jungledave45
CLK 320
I would say yes, develops after around 5 mins normal driving from cold.
00slk
Cambridgeshire UK
I had a similar issue with my eclass 320. Turned out to be the torque converter locking up. I changed the TC and did around 900 miles and the same problem developed. Possibly the used TC was on the way out?
However I kept driving it and if gradually got worse and changes were very snatchy and the gears would start to slip under heavier acceleration. A couple of days ago I fitted another replacement Transmission and TC and it changing lovely now.
jungledave45
CLK 320
So how will I determine what TC I need to purchase?
