general FUSE question
Status
Not open for further replies.
thekeeper24
New York
is it possible/ does it matter/ do you need the fuses in the fuse box to start a car? (besides any fuses for the plugs & starter?)
i know it sounds obserd but, im pretty sure there is some major short somewhere where the power is draining and since its sitting in a parking lot where its freezing cold, im looking for a quick fix)
-just any thoughts would be appreciated, thanks
ianallen2
leicester
If the power is being drained from the battery while the car is left overnight or longer periods , it could be the starter moter that is draining the power . I dont know about mercs but to check if the alternator is working ok is to disconnect the battery while the engine is running . (Works on most cars) . If alternater is faulty , the engine will die , If alt. is ok the engine keeps running . If you try the alt. and engine runs still , then i suspect its the starter . Some auto electrical repair workshops may test the power for you either for free or a drink .
T
thekeeper24
New York
yea alternator & voltage regulator were just replaced. i was just curious if that crazy idea would work
guydewdney
Tring, Herts
www.atct.co.uk
i'd disconnect the earth strap on the battery - put an ammeter in there in series and see how much current is being drained.
THEN i'd pull fuses one by one until i saw a change in current. that then identifies the circuit still draining power...
just my tuppence ;)
Status
