There seems to be lighting at each side of instrument cluster but not on main speedo nor speedo-side of the other 2 dials. Can someone help & explain how to proceed to get behind the instrument binnacle. Thanks.
THE lower dash panel beneath steering wheel needs to be removed to take screws out of panel that sorrounds cluster then remove panel around cluster (clipped in at top edges)pulling downwards and out at top then you will see screws for dash cluster
