Saeedk1995
- Aug 30, 2021
- C350 2013
Hi all,
I’ve got a Mercedes e400d 2019 saloon. Recently bought it and got an auto watch ghost 2 immobiliser fitted by a specialist who does them around Manchester.
Since then the car has been driving under powered, feels almost like a dpf block. However, there is no fault signs coming up on the dash. So I took it to a Mercedes Benz specialist for diagnoses. I put the ghost on service mode and then he used the Mercedes Benz software to check, he found a few fault codes related to ignition. P253300 in the SCR (my adblue levels are fine) and U0426FA in motor electronics.
I’ve sent the pictures of the codes to the person who fitted the ghost immobiliser. I’m not sure what to do really and I was seeking to some advice. Could it be from the ghost immobiliser? The car was running perfectly fine before that was installed. On the same day I also had front and rear dash cams hardwired in.
Has anyone had this sort of issue before? At this point I just want to take off the immobiliser.
