The Engine Management Light is causing issues. The car was taken into my usual Mercedes dealer who advised it was related to an engine temperature sensor although a cold start would be needed to determine properly. They turned the warning light off and advised me to monitor. The light promptly came back on. So they did a cold start check and I was informed that the cause was related to the’ charge air distribution‘ this needed to be stripped and investigated. This was done and result, a new temperature sensor and seals fitted, all costing £600+ Less than 5 weeks later the light is back on! I am now told that the ‘coolant thermostat’ needs to be replaced! I do not see how these are connected and why this was not originally found by diagnostics etc? My understanding of this Light is that it relates to the Engine emissions system. I am concerned by competence here and/or being taken for a ride! Can anyone advise please. Also, are there no independent Mercedes Garages in Scotland? Thank you.
