markwilson8954
- Mar 14, 2007
Hi all, Sprinter 312d on a P plate 1996. i have had a fault with the glow plug curcuit. Ie one of the glow plugs went open curcuit. (HAd to be number 5 didnt it right at the back) anyway decided with it being sunday that i would remove the fualty one and change it with a more accessible one, then get a new one on monday, (today) and replace it so all were back working again. All that done but the glow plug warning lamp is still staying on indicating a fault. Is this normal and will it eventually go out or do i need to take in for the memory clearing. Also since i swapped the plugs around i have had great difficulty starting from cold. Engine turns over for ages with lots or smoke out the back as if its trying to start then all of a sudden after about 45 seconds springs into life. Any idea's.
Still doing this even with the new glow plug. Have double checked all the plugs and the wiring to them just in case but no cure.
Cheers
Mark
Cheers
Mark
