Glow plugs
cjaybee
New Registration
WDD1760122V030618
Hi, I have just spent £200 on a new glow plug controller only to be told I have to spend another £325 on new glow plugs, I understand this could be a tricky job. I have been driving with the warning lights on now for over a year without any issue; is renewing the glow plugs really necessary?
I thought glow plugs cost about £40-80 for a set of 6 and an hour to fit ?
matthew k
Winchester Hampshire
2005 320 cdi Sport 7 seat estate
I did mine (om642) with no issues. Just soaked the plugs over the course of a week, and used a 1/4 impact driver. Seems a good way to reduce the risk of snapping them.
Botus
S500/2010/500
modern cars use the glow plus on and off throughout the time the engine is running. they chop in and out based on running conditions and temps. hence why there's a controller ?
they are a normal service item... check on eBay on a BM its normal to buy the controller and the plugs as a set - every 60k miles
the ones in yours are no different.... its all beru stuff
mercman149
Aberdeenshire
190, 190e, 230TE (all 1989), C180 (1995), C180 (1996), 220CDi Turbo (2000) & ML280 ED S CDi 4-Matic
Morning,
Here's a relay query - code reader showed glow plug 2 as open circuit, so checked that the power feed was good with multi-meter and replaced the glow plug - code not listed anymore, however now showing glow plug 5 as open circuit. That glow plug was replaced at same time as number 2, so any suggestions as that code has never been listed before?
Keep reading that relays are prone to failing. How can you test if that is the case?
Morning,
I think the relays failing is indicated by trouble starting ? Or at least that was my relay symptoms
EmilysDad
Bury Lancs
ML350
Morning,
A while back ... a local indie said that STAR had indicated that number 5 glow plug on my R Class was goosed but he also suggested it could be the relay. In the event it was the relay
