M
muzzere320
Hi all
Just thought I'd share somehting I picked up which may explain the the widely differing views/experience of these tyres.
Apparently they are made in Germany and Thailand. The German made ones perform really well good ride, grip no early on set of sqeeling etc. The Thai made one are seeminly not so hot, sqeeling early, indifferent grip and nobbly ride and lacking the superb wet road performance of the German manufactured ones. Why this should be so is a bit of a mystery although it could be the Thai made ones have a compound more suited to the material used in the road surfaces inn that part of the world. Either way if you are going to have them check the sidewall before they are fitted to make sure it has GERMANY on it
Cheers
Cheers
