Gremlins in central locking
philreed52
270clk
I have a 2005 270 clk and got out the car locked it as normal. Came back pressed remote and drivers door button came up ,passenger one went crazy going up and down 6 or seven times rapidly then stayed up . Drove home went to lock it same again .
Only passenger door does it ,tried other remote ,the same .it eventually unlocks or locks but just rapid up and down first.
Any suggestions ??
Sent from my SM-G950F using Tapatalk
Spring broken in the passenger door lock.
It’s quite common and there’s a lot of videos on YouTube on the issue
P
philreed52
270clk
Thanks didn't know how to describe it looked at videos on youtube ,might try temporary fix until I can brave the spring replacement and tearing door and mech to pieces .The video reckons the Coupe is hardest to remove lock just my luck .
Thanks for help guys
umblecumbuz
Wales and Gozo
... and cheaper to replace the whole lock than try to fit just a new spring.
The old lock, worn and stiff, is probably what caused the spring to break.
Get some spray lube into all your locks as well
P
philreed52
270clk
My local garage has quoted about £100 for door strip ,Would I be better supplying a used lock actuator that I could grease up, than getting them to fit new spring ? I'm getting a bit past sitting on floor trying to get actuator out myself . So could try prestige autoparts for actuator (used them before and they seem reliable ) and supply part .Any thoughts ?? I'm sure new part is going to be stupid money .
umblecumbuz
Wales and Gozo
Isn't that a piece of string question? Who can give you a definitive answer?
If the garage will remove the lock mechanism within their quoted price, maybe it'll be cheaper for you to buy a new spring and spend time fitting it yourself.
Just a thought ...
www.W140.co.uk&www.r129.co
