Hard wire dash cam
Merc mat
E220 2012
As anyone hard wire a dash cam in to a e220 merc , ?
onefortheroad
uk.
Probably loads have m8. Pull the cover off the side at the end of the dash and see if you have fuses . Check passenger and drivers side. If not youll have to find a live feed and an earth.
Easy enough, just take a feed from the back of the 12v socket
Merc mat
Merc mat
E220 2012
My fuse box is under bonnet, so how does the centre part come out were my 12v socket is , ?
onefortheroad
uk.
Mercs have more than 1 fuse box. I gave you 2 . Good luck.
dry run
Portsmouth
kb-boatpark.co.uk
CLS 350d AMG LIne Premium Plus
I find the best way of fitting a dash cam professionally is with a credit card. Just take it and pay someone else to do it properly! Got my front and rear dash cams (Thinkware models) supplied and installed for £400. Very professional job and warranty included :)
EmilysDad
Bury Lancs
ML350
but it costs just a few quid to tap into an existing fuse circuit or use the provided 12 volt supplies on the side of a SAM ;)
onefortheroad
uk.
Think I paid £8 for my hard wire kit . Piggy backs included.
Merc mat
Merc mat
E220 2012
I have the hard wire kit , just wasn't sure the easiest way to wire it in , either in to fuse box or 12v socket, in the fuse box the wire piggy backs the fuse so il see how it goes
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
If you follow the loom from your engine comp fuse box towards the bulkhead you'll find a small loom disappearing through a rubber grommet in the bulkhead, push a thin stiff stick through the grommet and you will be able to fish it from the open end cap of the RHS of the dash where you will be able to stash the PSU then run your power lead around the window trim.
I seem to recall one side of interior light may provide a good 12v source too.
