squealinneil
- Jun 26, 2004
Over the last week the radiator light on my '89 2.6 auto has been coming on. The coolant level does drop by about 2 inches after topping up, but there was still coolant clearly visible in the expansion tank and the car wasn't running hot. It was booked in for a 12K service today so I just kept an eye on it.
I used the car to go to Windsor Races last night and was stuck in a crawling traffic jam for about 30 mins. The temp rose higher than normal but was no where near the red.
Today I brought it to the independent I use. He was busy signing in other customers so I checked the expansion tank to see if there was any difference. The COOLANT (I emphasise the word coolant), acid greeny yellow in colour, was 2 inches low but apart from that all was well.
Get the call to pick the car up this p.m. "Any surprises?" I ask. "Yes, the ATF is mixing with the coolant in the rad. New rad needed." I go over to pick up the car and the expansion tank is now full of bright red ATF. I say how can this be, when I checked it this morning it was full of coolant?
They don't know what happened. No idea. The mechanic who worked on it said the expansion tank was full of ATF when he opened the bonnet. They say the rad has a small leak (hence the drop in level) anyway so I'd need a new rad in any case. In fact, lucky me, I have two problems which can be fixed with one new rad.
Apart from the timing being amazing, in that the expansion tank filled up with ATF in the time between me leaving the car & the guy opening the bonnet, there was water and ATF in the dimple of the expansion tank and dribbles of something oily below the ex. tank. They said they added no fluids.
Should I give a big sigh, light a ciggie then roll over and fall asleep? After all, I feel like I've been rogered good and proper.
What do you think?
What do you think?
