have to ask
hopeful
clk cdi2.7 auto coupe 2005
2005 2,7 clk cdi and 2002 c220cdi do either have dpf .of course i should know , ha , i do use a a liitle cataclean on the test don't get to do many long runs nowdays
hopeful
hopeful
neither do i was just checkin'
oil change due soon both cars going to use this
TRIPLE QX Fully Syn 5W-40 A3/B4 - 5Ltr 229.3/226.5​
Put your vin in 7zap to make sure you have no dpf.
Or call a merc dealer and ask.
Around that time of your car, i believe dpf were just taking off and possibly an optional extra.
hopeful
hopeful
oooh no don't say that
7zap ?
looked cant see , tried emissions and exhaust. no say
Gazwould
C250 CDI
You might aswell use the later lower ash oil as it's higher performing oil .
Reduced ZDDP anti wear is about having enough sacrificial zinc for the drain period .
Reduced can always be offset with friction modifiers and a better oil basestock .
Too much zinc can be detrimental , often a fine balance of ingredients .
I take this further and use a VW spec oil with a dual petrol and low ash diesel spec .
rf065
Grossbritannien
Pretty sure a 2002 and 2005 CLK is too early for a DPF, I seem to recall the DPF was an optional extra by 2007 though.
philreed52
270clk
My 2005 270 clk doesn't have DPF as that was one thing I didnt want when I bought a diesel. I previously had a citroen with DPF what a nightmare,as wife did fairly short runs always in limp mode or garage !! Mind you it was a french car lol
Sent from my SM-G950F using Tapatalk
If the inside of the exhaust is clean you have a dpf , if it looks like the dirtiest darkest hole the human eye can gaze upon then you don’t have a dpf :rolleyes:
