5w155t0ny
- Oct 18, 2021
- R230 SL350
Afternoon guys,
My recently acquired R230 has an apparently dead Comand head unit.
The red battery warning was on the dash when I collected the car but was listed as a stored fault, so I used my iCarsoft and cancelled the error, which then disappeared.
It came back on for around 10 seconds a few days later but vanished again.
I have a voltage meter plugged in and battery is charging at 14.1 when running so no alternator issues.
Disconnected both batteries for around 2 hours last week in an attempt to reset the head unit but still won’t fire up.
Have got a new Kenwood head unit to go in but don’t have the correct cables to connect as I have just discovered the car has an amp fitted, along with the DVD nav unit and cd stacker.
Does anyone know the cable connector I need but also if there are any other possible reset procedures for the Comand unit to see if it dead or just resting?
The other issue I have regarding checking fuses on the Comand is mine seem to have a lot less fuses and fuse sockets than is shown on the available maps, so not even sure if it might just be a fuse?
Sorry for the essay, maybe pics will help?
As you can see on the fuse photo, fuse 77 does not exist, so is it all powered through the amp?
TIA
TIA
