I have a SLK 230 and have noticed that the headlamp flasher is not working, although main beam is via the operation of the stalk when the headlamps are on. I have checked the fuses and they seem ok, could it be the relay, if so where is it located.
turnipsock said:are you talking about back emf? usually there is a diode to stop the relay being damaged. I'm sure that MB will have covered this.
No, I said some people fit a diode, Not MB.
And the part that that gets damaged is the switch contacts, not the relay. A cap is standard practice in electronics but not in cars through some reason.
Malcolm
