Headlamp washer fluid leak w210
suzz
I am fairly new to the forum, and this is my first post. I have recenlty bought a Mercedes W210 estate. It has a headlamp washer fluid leak. It empties the washer reservoir fairly quickly, and is leaking from the back of the lamp washer nozzles. Does anyone know if there is a grommet or washer that needs to be replaced, or does the complete washer nozzle need to be replaced. Has anyone else experienced this problem. Can anyone point me in the direction to the headlamp waher system diagram?
Look forward to any replies.
Regards
Suzz
SilverSaloon
w124/1994/om606
Regards
Suzz
sounds to me like the tube may have slipped off the connector on the back or the pipe has split
suzz
I am away until the end of the week now. I shall have a look at it on Saturday, and post back my findings.
suzz
Hi All,
The leak was not from the pipe connecting the washer jet. It appears to be leaking from the washer jet itself. Water is leaking on the jet where the body of the jet can swivel round. Looks like a new jet is required. I have disconnected the pipe in the mean time, and capped it off, to stop any further washer fluid leaking. Does anyone know if it is easy to replace the washer jet? Does the lights and the bumper need to be removed to replace the washer jet?
Regards
Suzz
Myros
R107, S211, R170, C219
I'm assuming you have the facelift model
with the jets in the bumper.
http://www.detali.ru/cat/oem_mb2.as...GA=722.626&CT=F&cat=66G&SID=86&SGR=030&SGN=01
This looks simple, until you take it into context with the front bumper
http://www.detali.ru/cat/oem_mb2.as...GA=722.626&CT=F&cat=66G&SID=88&SGR=030&SGN=02.
You can get at the foglights from the flaps underneath the bumper spoiler, but i can't remember whether you can get at the washers. It might be a bumper off job, which is a bit of a pain.
If it's a pre-99 version, it might be easier, as the jets aren't in the bumper, as I recall.
Sorry malcolm, I crossed with your post while i was replying. No clash intended.
Thanks no clash all the more the merrier,,as you mention the bumper. I was thinking about the bumper too,,if the OP would like a bumper off paper i can send him one, just need to know if it is a face lift car or not
suzz
Hi Guys,
Thanks for the update. The mercedes is a face lift model, so i suppose the bumper will need to be removed.
Cheers
Suzz
Hi Guys,
Cheers
Suzz
If you need the paper I need your Email address, if you put it up this evening you can delete it in "Edit" when I say
suzz
Thanks Malcom,
My email address is
Cheers
Suzz
Its sent,, go to edit and remove Email address
suzz
Thanks Malcolm
