Headlight bulb replacement on a r171
00slk
Cambridgeshire UK
Hope this hasn't been asked before, couldn't find any reference, low beam headlight bulb has failed and so has the left side light on the SLK350. (well the n/s has been intermittent for a while :oops:) Does the front bumper and headlights really have to be removed to change the bulbs?
davidsl500
Home : Derbyshire at the moment !
R172 250CDI Gone..!, R129 SL500 Gone...
If you don't know someone with small hands to do it from the top then I think you can do it by removing the front section of the wheel well liner (remove wheel or turn it in to get to the liner. On some liners you can just remove a couple screws/bolts and flex it out of the way..
Very very easy to do :)
Jack up and remove relevant front wheel, with 10mm and 8mm sockets remove the front of the wheel liner. 10mm inside the wheel area and 8mm under the front - very easy to get to them.
You then get clear access to the back of the headlight. I've had to replace both dipped beams on mine (£4.75 for the pair...nothing like LED pricing...) :cool::p:D
I knew I’d take a couple of pics when I did it... :p
00slk
00slk
Cambridgeshire UK
Many thanks for your replies, and to Blobcat for the illustrative pictures.
I now know what I will be doing tomorrow morning before I go to work :)
If it takes longer than 20 mins including the smoke afterwards you're milking the job :D
00slk
00slk
Cambridgeshire UK
Job done .
Sure was easier than trying to go though the top.
