Headlight Issue
Mersaydeez
Registered
07 A Class
Hello all
Having an issue with the NS headlight on an A Class W169. The dipped beam isn't working. Changed the bulb; still not working. Put a voltmeter on the 2 wires at the bulb, and the reading is about 11v, which then slowly drops down to about 7v. Checked the larger connector on the headlight assembly, which looks 'all good'. The yellow and brown wires display the same voltage dropping issue.
There are no fault codes showing.
I've tried to gather some info, which keeps referring to SAM, but whenever I look for images, I just find a block with fuses, relays and loads of wires. I'm struggling to make sense of this. Can anyone help?
