Headlights (UK -> EU) Sprinter 313CDI 2015
matt penrice
CDI313 2015
Hi there,
(I saw the pinned headlight adjustment thread but doesn't cover sprinter)
Am trying to register my 2015 313CDI Sprinter in the Netherlands but it's failed on headlights as expected.
Trouble is, i have contacted many MB garages and they all seem nonplussed about what's required to do the conversion.
Does anyone have any experience with what is required? Below are photos of my headlights - i'm not even sure if they are bi-xenon/halogen to be honest so any advice would be great.
RfdTqe3
RfdTqe3
Mark A
Aberdeen
58 ML-320CDI.
Halogen lights. I suspect it is a new set of light units, you should be able to pick up after market units on eBay etc... others will hopefully confirm if there’s a cheaper way to do it.
M
matt penrice
CDI313 2015
I'm fairly consigned to getting new lights but still unsure about compatibility with UK wiring etc.
There just doesn't seem to be any authoritative docs around :shrug
Craiglxviii
Cambs UK
The lamps should be plug and play. The only difference between RHD & LHD is the best pattern, the wiring should be identical.
For this vehicle the lamp units will need to be swapped out.
M
matt penrice
CDI313 2015
That sounds authoritative enough for me! Thanks
Would a clueless millennial be capable of such a repair (with help of Youtube of course!)? I assume there'd be some degree of calibration required?
Craiglxviii
Cambs UK
I think each lamp is secured with 3 bolts, and they all have alignment adjuster devices built in. May require front bumper removal.
M
matt penrice
CDI313 2015
Do you have any info on how the alignment adjustment would work pls - i'm hoping to fit this on a car park before taking into the inspection centre. I have the usual tools, nothing specialist
Craiglxviii
Cambs UK
Yep. They’re usually two little screwjacks built into each lamp to give lateral and height adjustment. Park the van facing a wall, turn the lamps on before you do the swap and take a pic of the beam pattern, specifically the height of the main brightness cone. Once you’ve done the swap, then fiddle with the adjustment screws to replicate the beam pattern as a mirror image using your pic as reference.
M
matt penrice
CDI313 2015
That's very helpful thanks again
M
matt penrice
CDI313 2015
After researching a good deal and learning much about the NCV3/906/313 vehicle I have found these very well priced lamps -
https://www.carpartsdirect.nl/van-wezel-3077962-koplamp.htm?typeCode=42840
Obviously it's not official MB part but a reputable retailer. What's giving me pause for thought is that the lights mention "electric light field control" which seems at odds with what you mention about manual screwjacks. Also, hard to tell whether these include indicators?
Craiglxviii
Cambs UK
That should be the beam height adjustment, some cars have it manual, some automatic.
M
matt penrice
CDI313 2015
Bit of a bump but finally got round to having the lamps i mention above fitted and the plugs are incompatible. Specifically the pins don't align in 3 locations.
This is the new unit connector:
This is the existing unit connector:
This is the product page for the new units again - https://www.carpartsdirect.nl/van-wezel-3077962-koplamp.htm?typeCode=42840
Does anyone have any advice on compatibility or if suitable adapters exist?
Thanks,
Matt
Oldspanners
Normandy
C CLASS 2004 C180
Go to the above link and put your VIN in and then go to electrical system/Lighting/Front illumination and look for a part number for a lamp with Right hand traffic. I had a look at https://mercedes.7zap.com/en/eu/fg/...cdi+218cdi/62x/906613/fg/0/0/82/0/175/0/0/#10
but I'm not sure if it's your model but it doesn't look like there's an EU version just Canada and USA a quick look came up with
https://www.daparto.de/Teilenummernsuche/Hella/1ej011030151 on a German site which I use but the photo doesn't show the connector but try searching the Hella reference.
The simplest way of course is to get the compatible light but I had trouble with UK Jeep and ended up having to change the connectors which involved wiring diagrams and soldering.
The other things to look out for is that the lights have the EU markings and go and get the alignment done at a garage with the right equipment it's cheaper that a return visit.
Good luck and do a lot of cross checking of numbers.
EDIT More here using the OE number on the site you used but they may well have the same connector but there is one at €70
Oh they also have a site in the Netherlands.
Found this has a view of the connector on the Hella but with my eyes it's not very helpful.
M
matt penrice
CDI313 2015
Thank you very much for the info (and looking so thoroughly)
Using the VIN approach leads me here - https://mercedes.7zap.com/en/eu/fg/...0/0/82/0/175/0/0/?param=vin:wdb9066352p133351
As you can see, there is no mention of right-hand traffic. Even more worryingly, it explicitly says "REGISTRATION OF VEHICLE NOT POSSIBLE IN EU"
I assume my VIN maps to a UK-specific variant.
Hmmm, I'm unsure what to do next. Without some way of ascertaining whether the connectors are actually compatible between the right/left versions I think buying another set of lamps is likely to just put me in the same situation (i'm pretty sure the ones i've already bought are the correct corresponding lamps).
Is there a way i can reliably find a diagram of a corresponding right-hand traffic lamp connector? I could take a trip to scrap yard but finding the right year etc could be too time consuming
Oldspanners
Normandy
C CLASS 2004 C180
I wouldn't be put off by the "REGISTRATION OF VEHICLE NOT POSSIBLE IN EU" as that will be referring to the Canada/USA model of van with different engine etc. and they have different lighting regulations as well. The UK model won't be a problem as until recently it was EU. There's a paragraph in the V5 which shows the tester this.
I would return the lights you bought and ask either one of the suppliers to send a photo of the light connector or go to a local Mercedes dealer or Auto factor and ask to see one. As the photo on the Oscaro site shows one although not clear enough for me to identify as the right type I suspect it's just a matter of finding the right one and certainly if the one's at €70 each come up that would be a result.
It'll work out and then you can post a definitive "How to" for those who wish to follow.
Oldspanners
Normandy
C CLASS 2004 C180
Just got out my best magnifying glass and the Hella lamp on the Oscaro site has the same pin layout as yours small pins in 1,2,4 large pins 5,6,7,8,9,10 and small pin in 12. All you need to do now is take the reference and find one at a good price or a compatible.
Edit Odd just fitting some new indicators to the Golf yesterday and had some Van Wezel ones, but the connectors were nothing like what they should have been and ended up keeping the existing connectors after a bit of soldering.
M
matt penrice
CDI313 2015
  • #17
Oh wow, I was doing the same earlier but don't have that trained eye i suppose. Your help is much appreciated - this is a bit of an ordeal for a clueless office worker
Because I was at a bit of a loss earlier I followed the process of using my VIN to locate the same (UK) units that's i'm swapping, and then simply swapping to "right hand traffic" (using autodoc.nl). I take most comfort in knowing i'm getting the correct corresponding units (as far as autodoc's records dictate).
This has again led me to the OEMs:
"906 820 05 61"
"906 820 06 61"
Units purchased:
- https://www.autodoc.nl/hella/929603
- https://www.autodoc.nl/hella/929602
As a result of my last purchase with this same OEM but incompatible connection, i went ahead and purchased a couple of Hella units. It sounds like this was the right move given you've seen disparity in the connectors with non Hella parts.
They should arrive tomorrow and i'll update the thread with all the numbers. This will include the fog lights as i've been through this process also
Oldspanners
Normandy
C CLASS 2004 C180
"906 820 05 61"
"906 820 06 61"
Units purchased:
Looks right from what I can tell hope the connectors are correct. I found the same on https://www.daparto.nl/Teilenummernsuche/Hella/1eb247012021
Good luck and have a bright summer:cool:
M
matt penrice
CDI313 2015
  • #19
Thanks.
Seems I've gotten things muddled somehow.
The OEM I bought before but didn't fit was this - "906 820 02 61". You're confirming that the pins look like a match. This may be explainable as you say however by the non-Hella manufacturer.
The OEMs for this next set i have arriving are:
"906 820 05 61"
"906 820 06 61"
which is obviously different. I'm fairly confident in how i arrived at this new set of number
I guess proof is in the pudding tomorrow
Oldspanners
Normandy
C CLASS 2004 C180
Thanks.
"906 820 05 61"
"906 820 06 61"
1EB 247 012-021​
1EB 247 012-021
The Hella number is the same as I found just a better price on Daparto so looking OK.
