heated rear windscreen
Status
Not open for further replies.
lordbarwick
hi guys,
my heated rear windscreen is not working, when the switch is pressed the red l.e.d does not light up. i have a Haynes manual but there appears to be no wiring diagram for the 'heated rear windscreen circuit'. does anyone know where i can find a wiring diagram so i can trace the fault
thanks
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
You dont mention which model you have, but I would check the fuse first.
Regards
Mike
L
lordbarwick
hi guys, i've checked the fuse and its fine, its the switch i'm having problems testing, the car is a 1997 C180 Classic, when the switch is pressed the red l.e.d. does not light up. when i've dismantled the console to gain access to the switch, the switch is part of a printed circuit board with a wiring loom with many wires, this is why i need a wiring diagram. thanx guys.
Status
