Heated Seats W210
alloy36
Hi, I have W210 2001 cdi and the heated seat has packed in. the back and the passenger seats heat up fine. But the base of the drivers seat no longer heats up? where should i start looking to cure the problem? cheerrs
jibcl500
Cambridgeshire
CL500,ML55,SLK280
sounds like the element int he seat has broken, replace the element is the only thing to do unless someone here has had the same problem and knows otherwise.
jib
Parrot of Doom
Manchester
I will be removing my own seats shortly, to clean underneath and also the covers, and to also tighten the driver's seat up (198,000 miles of arses takes its toll).
I will post what I find.
Check underneath your seat first - there are connections under there, one will be for the heating. Make sure none have been dislodged.
