Heated Wash/Wipe System
Bay Leaf
Stockport
SL 350 R231 2013
Hi Does anyone know how the heated wash/wipe system works.:geek:
EmilysDad
Bury Lancs
ML350
I know that some cars have a coil containing engine coolant routed through the washer bottle but often it's just the washer nozzles on the bonnet/scuttle that are heated, not really to heat the screen wash, but to just prevent the nozzles from freezing.
Bay Leaf
Bay Leaf
Stockport
SL 350 R231 2013
You might have something there, as there is an auxiliary pump in the engine compartment that's connected to the cooling and washer system.
EmilysDad
Bury Lancs
ML350
You might have something there, as there is an auxiliary pump in the engine compartment that's connected to the cooling system.
that'll be either for the heater ... ie so you can run the heater while the engine is stopped for half an hour or so (the engine needs to be hot in the first place) or to dissipate engine heat when the engine is switched off (my Omega used to do the same)
Usually just the nozzles are heated so the reservoir can still freeze if you don’t add sufficient screenwash
V6Matty
Newark, Nottinghamshire
It’s actually the nozzles and also the pipe work that are heated, there is a very fine wire that runs the length of the pipe work that goes on under 2 degrees I believe,
EmilysDad
Bury Lancs
ML350
pretty sure it's just the nozzles that are heated on mine .... no trace heating
mioba
Nottingham and Köln
you mean the pipes in the wash reservoir surely and not the rubber pipes that go to the nozzles. Or are you driving a Maybach or something.. :)
EmilysDad
Bury Lancs
ML350
in the likes of Practical Classics, you used to see a moulding of what was effectively a short section of top hose with a washer hose wrapped around it. You inserted it into the top rad hose and connected the screen was hose to & from the pipe that was 'wrapped' around it. I've looked but can't find it any more.
V6Matty
Nope I do mean in most mercs, the thin wire runs all the way with the pipe work, or at least it had with my 211, the 169 and the 212
S500 Pete
Essex
S500 (W222) 2014. Turbo 4.7 V8 with loads of toys. Superfast luxury.
My W222 has a metal coiled pipe in the washer battle that I assume is the heater coil.
RhodieBill
Central South Coast. (Previously Out of Africa).
2001 W208 CLK320 182U ALMANDINE-BLACK METALLIC
Heated Wash/Wipe usually means the Washer Fluid Bottle is heated by the Engine Coolant Fluid running through a Metal Coil that is located with the Washer Bottle. But you will also find that the Nozzles are also heated with Electrical Elements within them. That is why it is important never to use water from the tap as they will form Scale like in your Kettle and eventually get blocked. They are not cheap to replace!
You can see here on my CLK the 2 Pipes going into the Washer Bottle.
RhodieBill
Try the Ashbeck by Tesco. I tried a multitude before I found that was "The One"! (And the cheapest!).
I bought a Lidl Glass Kettle about 4/5 years ago and still looks good. All I do is rinse it out occasionally with the Ashbeck, but never washed it - never had to!
