Heater blower resistors.... location?
Status
Not open for further replies.
garygmb
I have checked that the blower motor is working, and the switch is OK too
but still the fan refuses to turn, I can only assume that the resistors have gone for a burton,but I don't know where they are located.Could some one tell me where I could find them,and what cost for new ones?
Thanks in advance
Gary
G
garygmb
MEDEL????
ah!!!! MODEL (sorry couldn't resist that).
True true a model ID would be a good idea,its a 190e.
TimN
Hertfordshire
If none of the settings are working then I would check the earth and the supply first. Sorry don't no where the resisters are on that model but places to check would be inside the engine bay against the bulkhead, behind the dash on the driver's side, contained in the fuse box, part of the switch, part of the blower etc
Regards
TIN
joe bloggs
The fan would run on full regardless of resistors, if not then check supply, fuses can melt into fusebox, may look ok, also as supply comes from seperate ignition switch contact - could be ign switch, try wiggling key with fan on full
Status
