Heater blower stuck on max
Bikesnoopy
Ilfracombe & Bristol
2003 A210 Evo
Hello. . .
I know its not usual to join a forum with no introduction & go straight in with a question, but i'm desperate!:(
I've just bought a beautiful 2003 A210 Evo LWB & i love it to bits.
Its in perfect condition in every way except that the heater blower is stuck on max.
The distributor control works fine. The temp control works fine. The air con works fine. Its just the blower.
It doesn't matter what position the switch is in - 0, 1, 2, 3, or 4, it still blows on max as soon as the ignition is turned on & the only way to turn it off is take the fuse out!
Can anyone shed any light on this, or have i bought myself a load of expensive trouble.
Apologies once more for joining the forum with a "help me" question!
I hope to participate more in the future:)
Regards
Denis
whitenemesis
CLS55 AMG '05
Welcome to the forum :)
No need to apologise! That's what we are here for and some one will be along soon with suggestions
B
Bikesnoopy
2003 A210 Evo
Anyone got any ideas?
Im driving around with a gale blowing up the screen. . . OR im misting up if i want a bit of peace & quiet & take the fuse out!!!:(
huey
Nottinghamshire
W203 cdi 2004 Estate
I would guess the resistor is shot:sad:
huey
Nottinghamshire
I priced one up for my 124, yes expensive, luckily it was'nt that, it was one of the fans stuck and I was able to fix it.
If you read the link Whitenemisis put up for your model they are not expensive.
whitenemesis
CLS55 AMG '05
Read the link I gave you! It's explained in the write-up.
B
Bikesnoopy
2003 A210 Evo
£23.93 + vat for the part. . . & 20 - 30 minutes to fit? Am i reading that right?!
If so, that's a breeze!
The only thing is, that the problem in the link isn't EXACTLY the problem i have.
His fan only worked on max. . . but in other positions, it would turn off. I could live with that for a bit.
However, mine is STUCK on max. It doesn't matter what position the switch is in, it still blows on max. The only way to shut it up is to remove the fuse, or switch the ignition off.
Does this sound like a resistor problem, or something more sinister. . . :|
whitenemesis
CLS55 AMG '05
Get the car on STAR and read the fault codes.
whitenemesis
CLS55 AMG '05
STAR is the Mercedes diagnostic system. It can interrogate the car's systems and help pinpoint the problem. All dealers and most good independents have it.
Frontstep
T210 320cdi
Sounds like a resistor problem to me.
They are a common failure it would be cheaper to fit the resistor than pay for a Star diagnosis.
B
Bikesnoopy
2003 A210 Evo
I'm a Service Advisor at a Vauxhall Main dealer.
I guess Star is Merc's equivalent of Vauxhall's Tech2 then.
Yes, i was trying to avoid having to have diagnostics done by a Merc dealer. . . I know how much I charge for diagnosis at Vauxhall . . . !
Maybe i'll just get a resistor & fit it. If it not that, ive only lost £30. . . :|
Frontstep
T210 320cdi
The resistors are becoming so unreliable they will become part of a service soon, the Chinese are turning millions out.
B
Bikesnoopy
2003 A210 Evo
  • #17
I'm just not convinced it's anything to do with the resistor.
If it was that, it would "default" to max, but switch off in all other positions.
Could it something as simple as the switch has failed. . . :idea:
michaelr1946
Banned
milton keynes
e320cdi Avantgarde estate 2001
Hi , had this happen a few weeks ago , only difference was mine kept going with ignition off and key out !. It turned out to be the blower "control module" shorted out , got it replaced , part cost was around £80 and then a couple of hours labour to do it .
Cheers
Mike R.
B
Bikesnoopy
2003 A210 Evo
  • #20
Found it!
Its the heater control unit.
Can get one for around £45 & get it fitted at work, so just a cheap fix.
Excellent result :D
