heater control bulbs, w124
fatboy
hi, can anybody help? how do you change the bulbs in the heater controls (fan and air direction dials) on a 1996 e200 w124? thanks in advance for any answers. rod.
F
fatboy
hi, thanks for the info and diagram. i've tried pulling the dials as hard as feels comfortable with pliers but they don't seem to want to move. should i give them another shot but harder?
E
evo-number-one
Without this turning into a "Carry On" sketch full of inuendos.... I had right fun and games pulling my knobs off too!:rolleyes:
Although they do just pull off, one of mine was like yours, really tough to shift. In the end I used a very long think screw driver to prize it off while I pulled and wiggled my knob (No Matron!) . Go slowly and be carful not to mark the outer ring it sits in.
Attached (by 4 short plastic stems) on the back of the knob itself is a thinner plastic grip that slots over the shaft where the bulb sits. It is this bit that gets stuck and makes removal difficult. You may find that in prizing the knob off this way, this grip comes off and stays on the heater - if it does, remove it from the shaft and clip it back to the knob with a blob of superglue on the stems.
If you find that the bulbs you have are the frosted type, make sure you get the same wattage (I think they are 0.4w) and do not accept the Dealers blurb that you can only now get 0.5w clear bulbs which they claimed were a direct replacement.
The clear 0.5watters heat the knob to Chernobyl strength giving you a right scalding shock when you unsuspectingly go to adjust them the first night after replacing.
Go to a motor factors and source the glazed 0.4w, or if you cannot source anything other than the 0.5watters, fit those into the headlight switch surround (where they are not fully enclosed and do not overheat anything)
and the foglight pull (where they would be used less often) and put the glazed ones from there into the heater knobs.
Sounds a bit long winded, but boy did that extra 0.1w burn:mad:!!!
As above. they are tight, we used to use some fishing line behind the knob and pull that
F
fatboy
thankyou very much for the information. i shall be arming myself with screwdrivers, fishing line and superglue this week. cheers chaps, rod.
