Heater Fan Rear Stat/Resistor Pack
mlsports
Hi Guys
Below are images of the Heater fan in my 1997 E230 estate, which has air con and climate control.
I have had the unit tested and it is the rear stat unit (aka resistor pack, apparently) which has failed - the fan itself will work.
Any idea if Mercedes still make these????? It has no part number on it that I can see (??)
I found a second hand fan to match this one with Mercman breaker - but they'd taken the rear stat off of it - thus making it useless for me :x
I'm knocking my head against the wall trying to get this fixed.
Any help much appreciated!!!
:eek:
M
mlsports
  • #2
images
forgot to add the images :confused:
As below
:eek:
Hibbo
East Scotchland
I'd try contacting Siemens directly and quoting the part number on it.
Is it openable or is it a sealed unit?
M
mlsports
Openable
I believe the unit can be opened, but it is sealed in 'amber' - that is to say that it's covered in something that kind of looks like amber - meaning you cannot access the components.
I contacted Mercedes, and they said:
The resistor pack has been superseded and now requires four items to replace it including the heater motor-
A2108211651 £194.77
A2108201017 £18.38
A2108206742 £314.67
A2108352840 £41.19
Total price £569.01 including vat.
Looks like I need to keep checking the breakers yards :neutral:
M
mlsports
10 years
And I thought Mercedes were supposed to guarantee to make replacements parts for at least 10 years.
I guess you could argue that they are 'replacement parts' - four of them and ****** expensive :mad:
mattkh
England
A160 W168 1999 1.6
I have had the unit tested and it is the rear stat unit (aka resistor pack, apparently) which has failed Any help much appreciated!!!:eek:
Open it up and replace the faulty resistor or two.
If it is repairable I can do it for you.
Malcolm
Hibbo
East Scotchland
They are not 'resistor packs' as such anymore, they are continuously variable as opposed to 0-1-2-3 speeds. They are basically just a big transistor in series with the motor, and can burn out as they carry a lot of current (hence the huge heatsink).
If it can be opened it would be easy enough to replace it - cost of transistor? £3 tops!
Malcolm has already stepped into the breech before I had a chance! :)
BlackC55
South coast
C43
Its called a blower regulator and IS available from Mb dealers as a seperate part.
M
mlsports
replies
Hi Guys
Malcolm: would be great if you could! What woul dbe the damage for the repair work?
Hibbo - Ah yes, I see. So it is a variable control rather than the three step for three fan speed jobs. I'd love to get you or Malcolm to repair it! That would be great!
BlackC55: Are you 100% sure on that? The reply I got (above) was actually from Mercedes. DO you have a part number?
Let me know guys!
:eek:
If it is not potted and I can get to the output device, the cost is near zero.
Malcolm
M
mlsports
potted?
Not sure what potted means :-?
The fan is out of the car so I could mail it to you, or remove the resistor pack (I assume it's removable) and mail that.
Let me know
:eek:
Let me know
:eek:
Potted means encased in resin so that you cant see inside.
I do not want the whole thing, just the little pack.
Malcolm
M
mlsports
potted
ah - I see.
I beleive it is in resin - at least the guy who did a service for me (very good by the way!) told me they usually are. Are they easy to open up once they're removed from the fan case? If so I'll take a look later on.
:eek:
ah - I see.
:eek:
Sometimes i can get the resin out, it will cost you nothing for me to try.
malcolm
BlackC55
South coast
C43
ML sports
Give me a full chassis number and I will get you a part number.
BlackC55
South coast
C43
Sh1t should have read the thread properly.
The silver peice is available from MB but not the Siemens part.
M
mlsports
  • #18
Hi Guys
Hi Guys
Malcolm: can you PM me your address and I'll mail it over to you either way and you can see what you can do. Very much appreciated!!!
BlackCat: :D
:eek:
jberks
Are you all absolutley sure you can't get the resistor. I changed the one in my 2000 W210 a couple of years ago. It was called the 'fan regulator' and cost me £125 from the dealer. Just walked in and bought one. I'd be surprised if they'd changed much over the years - it certainly looks pretty similar.
