I?m newish to MB and brand new to this forum so be gentle!
The heating system in my 1999 W210 E200 has gone mental. I?m getting air from the correct vents but, with the fan control knob set to 5 (max), the output is barely enough to bend smoke! With the temperature wheels set to white or red I?m getting street air with a very occasional touch of heat if the wheels are set to max heat. With the wheels set to blue, the air is cooler (A/C compressor was replaced last year). When depressed, the EC button only lights when the fan control is at 3, 4 or 5. I?ve changed the pollen filter (on the advice of two MB dealerships), but to no effect. There does not appear to be any heat damage to fuses or holders.
I?ve checked this forum for advice (horrified to see how much trouble Mercs have with heating / cooling and the huge range of root causes!!!) Could the fan motor go into semi-retirement like this? Shouldn?t it either work or die? Is there a bank of resistors somewhere controlling the power to the fan motor?
Can anyone out there help? I?ve had more car problems in 14 months of MB ownership than in the previous 16 years and I need to fix this problem before my wife finds out and goes into her favourite mantras ?why didn?t you buy another Japanese car? Everything on ALL of your other Japanese cars worked EVERY time! Oh look, there?s a Japanese car. I bet its heater / air con / ignition keys / alarm / fuel gauge / steering lock / windows / etc. work properly. No, you can?t borrow MY Japanese car again.?
