Heater plug extraction tool
kebo57
Lanc's
ml270
Hi I finally got round to finishing that Heater plug extraction tool
I had difficulties pulling the heater plugs out after I had unscrewed them
So I made this tool its a split collet arrangement that shrouds the plug then the tube is slid over the collet (this tube will stop the collet from expanding during the extraction proses)
Then the extractor slides into the tube and screws on to the split collet so when you turn the nut down on to the end of the tube the plug is pulled out (see pictures below also two in the next reply)
Kevin
kebo57
kebo57
Lanc's
ml270
  • #2
Hi these are the other pictures
Kevin
kebo57
kebo57
Lanc's
ml270
How long did it take you to make that then ?
Hi delboy777 its hard to figure out I did the split collet about 12 mths ago
I reckon that would be around 2.5 hrs including some tooling
The tube & extractor about another 2.5 hrs its all stainless steel apart from the nut which was 3/4 X 16 UNF now its 20 mm X 16 tpi. it helps having one of the best lathes ever made (Hardinge HLV-H)
Kevin
kebo57
kebo57
Lanc's
ml270
Hi never did use this tool in anger till today when I had to plull the heater plugs on my ML 270. of course you need to unscrew the plug then as you all know by now that mostly they wont just pull out this tool will extract the plug with out having to use vice grips etc. I've took some pic's
S.Speed
Lancashire
Older Citroen Now :-(
Kebo57..
I am in awe of your engineering talents..
What a superb and professional job you have done..
If only you could patent the design..
I think you need to book a slot on Dragons Den mate..
Brilliant and skillful work Sir..
Its people like you who made and will make this country great and NOT those damned useless and deaf politicians..
10 out of 10.
