barnaclebill15
- Mar 24, 2015
- Location
- newcastle upon tyne
- clk220cdi/2006/diesel
For the past few days the heater is only warm, if i turn both control knobs to max you can hear the fan speed up but only low pressure at the outlets, if I do the flap reset air blows out full.
The system has always been strange, with both on 22C it would be ok, if I wanted more and turned them one click higher the fan would go to high speed, get very hot then slow down and even go to AC cooling and settle down so I did not touch them often but a few days ago it was only slightly blowing tepid air but the fan sounded as if it was on high, in the end I tried the control knobs on full but it is not doing as before.
I feel the heater matrix is not getting hot but I have done no work on the cooling system and the engine temperature is ok 88c.
The only other thing would be if the system is letting too much outside air in to mix with the hot air.
What to try first?
What to try first?
