stevesey
The throttle on my C240 is bugging me a bit. It's the remote fly by wire type with the throttle sender unit located remotely in the engine compartment, in front of the passenger.
The throttle pedal has a return spring then the unit itself has 2 very chunky springs that are mounted in line with the spindle and are twisted as the throttle is pressed. Spings are part no 99 here - the top one is shown the other is below the lever (part 84).
My gripes are
a) too much pressure needed
b) springs bind - so fit you attempt to gently apply a liitle more throttle nothing happens until you apply enough extra force to overcome the binding friction - then the throttle moves a couple of mm suddendly. Have tried some lubrication - no help (don't want to go too wild and contaminate the sender unit itself.
I'm considering modifying this assembly - to either remove one spring, or to hook the springs onto a different part of the assemly so start with lower tension (this lloks easy on the top one as there is a suitable point about 90 degrees from the current attachment point. Obviously I need to ensure there is enough force to close the thtorrle in the event of a cable failure, so need to be cautious.
Anyone else tackled anything like this? Drove a pre-facelift direct cable car today and the throttle felt so much better - decided I have to do something.
My gripes are
