Hello, Everyone!
Shawdow 63
2009 s63
New to the board. Look forward to exchanging ideas and information with everyone.
Shawdow 63
2009 s63
  • #2
Hello back i’m nearly new too
Just purchased a 2009 S63 with 50,000 miles. Everything works except the backup camera. Any ideas...what it could be?
Hello and welcome
A.J.
Norwich. UK
Hi and welcome to the forum :)
SmartAmg
2011 E class coupe 350 CDI
SL63 Mark
Wilts
R231 SL63 AMG
Hi there, that's quite a car. If the back up camera is the only thing not working, I'd say you got a good one.
mioba
Nottingham and Köln
Morning, welcome to the forum. It is great to see new members join. Do stick around.
Pics or we don't believe you
Shawdow 63
2009 s63
More to come....
Not having Backup Camera is racking my brain. I took left side trunk panel out. Can't figure out which wire is for the camera.
Srdl
New Forest, Hampshire
GLC43 AMG 2018 (X253)
Have you checked the fuse? This link may help identify the correct one:
Edit... just a thought, is your camera behind the Mercedes star in the boot ( trunk?). If so, does the star flip up when you select reverse because that could be the problem and it may just need a gentle thump.
Shawdow 63
2009 s63
Edit... just a thought, is your camera behind the Mercedes star in the boot ( trunk?). If so, does the star flip up when you select reverse because that could be the problem and it may just need a gentle In alone
Interestingly, there is no fuse in #141. Could the backup camera be a different fuse # for the 2009 s63 amg. See picture. Also, I Removed the left side trunk panel. Didn't see any damaged wires.
Shawdow 63
2009 s63
Perhaps that’s why it doesn’t work ;)
Okay. Ran a Vin Decoder on LastVin.com. No Rear View Camera (Code 218) . However, in Reverse, I get black screen with "Check Entire Surroundings." Also, there is a camera on the rear of my car...not dummy camera (wire attached to it).
So, is Rear View Camera installed BUT INACTIVE. You know, needs to be unlocked? Same with Parking Guidance (Code 230)?
Thanks in advance.
John Laidlaw
Wirral
Land Rover Discovery 4
As I said earlier post ' did you have it' , just because the bits are there on Mercedes doesn't mean they are (if that makes sense?), you probably need an Auto Electrician to confirm and/or see if it can be completed
