James Walters
New Registration
- Aug 4, 2023
- 2002 C 200 Kompressor
Hello. My name is James and I recently purchased a low mileage 2002 C200 kompressor. It has a few issues that I need to sort out and despite being a mechanic I can't seem to get to the bottom of them. I want to sort it as its a lovely car and I didn't pay a lot and don't want to scrap it. I have two codes that keep coming one is for the oil level and the other is for the down stream lambda probe heater. I replaced the Lambda probe with a Brand new Bosch one and I've changed the oil as it was a little over the mark and it needed doing anyway. Neither of these have cured the issue and I clear the codes and start the engine the management light stays off until you turn off and re start again and then it's on every time. I'm hoping it's not an ECU issue as the headlights are on all the time whatever the switch position. One 15 amp fuse in the under bonnet box was blown and the drivers seat keeps blowing its fuse, I don't know if this is related. Thanks in advance for any help.
