Hello! I'm a new member
Hywel G
SLK 250 CDI 2014 2.1
My name is Hywel and live in Tewkwsbury, Gloucestershire. I own a white 64 plate SLK 250 CDI. I bought it in 2016 with 18k on the clock and it now has 57K.
I've only just found this forum based in the UK, a bit slow I know.
Current issues I have are:
Clunking roof, tried Gummy Pfledge the rubbers, greased all the joints in the roof mechanism and still it clunks.
Intermittent alarm, checked the battery when rested and the stored charge was low. It was the original battery so got it changed. Issue still remains.
Hywel
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
Welcome to the forum.
The alarm issue may be a corroded battery inside the siren affecting the PCB. A quick Star test at a Mercedes specialist would confirm.
Only fix is a new siren from the dealers for around £110.
Its an easy DIY once you have located the siren. Usually in behind the drivers side wheel arch liner but some models are in different a place.
Bay Leaf
Stockport
SL 350 R231 2013
Hi Hywel What do you mean by clunking.
SmartAmg
2011 E class coupe 350 CDI
Welcome, Hywel. :)
A.J.
Norwich. UK
Hi Hywell, welcome to the forum :)
Hello and welcome,
You’re here now that’s what’s important
00slk
Cambridgeshire UK
2002 SL55 AMG, 2005 E320 CDi,
Hello and welcome. Clunking roof may just be requiring adjustment as they can work loose.
H
Hywel G
Hi Bay Leaf,
Going over little ruts, holes in the road causes a clunk from the back of the car. It also happens when the car causes the roof to flex a bit, eg when turning out of our driveway over the pavement and lowered pavement.
One area I want to explore is the boot lid. When I push down on the rear of the bootlid when closed, and roof up, there is downward movement of about 1cm. Would you know if this is normal or should it be solid, no movement?
Cheers
Hywel
Bay Leaf
Stockport
SL 350 R231 2013
Hi Bay Leaf,
Cheers
Hywel
Does it do it when the roof is down, if it does then it's probably not the roof. I've got an SL which is very similar to your SLK and there is no downward movement with my boot lid. You will be able to adjust it by moving the keeper ( that's the thing the boot mechanism grabs hold of ) down a bit so that will be trail and error. If any of that doesn't work it might be something to do with the rear suspension or maybe the exhaust.
Please be aware that I'm no expert by any means on the subject or even the car I'm just following logic. I'm sure someone else will be along with more experience than me to help you, but it will give you something to try in the meantime.
SL63 Mark
Wilts
R231 SL63 AMG
Sounds like suspension to me, have it checked on a lift.
Welcome by the way.
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Welcome my wife had 2 SLK200K's & now has a SLC250d, all three great cars.
H
Hywel G
  • #17
Hi, I've adjusted the bootlid as you said. A couple of torx screws loosend to move the lock receiver down a little, at a time, tighten up and bootlid now has no downward movement. This has solved the clunking I was hearing from the back. I reckon the bootlid lock was jumping a bit on the receiver going over little ruts. AND, the alarm hasn't gone off unintentionally since! So, I'm assuming it was affecting the bootlid sensor, I"m assuming there is one that is! Thanks, Hywel
