cruicky68
HI all,
My Father's 1989 G reg 190E has developed a problem with the central locking system. Using the key will only lock & unlock the drivers door. The same problem when you try the passenger door. There is also a fault with the toad alarm system which used to operate the central locking using a remote fob. Before the the alarm fault you could still operate all doors and boot using the key in the driver's door lock. Any ideas as to what is wrong, I've quicky checked fuses etc and everything looked fine.
Thanks in advance for any help.
