No cold air coming out of vents,air con drive belt working,tension on belt ok,revs drop when i switch air con on, im i right in saying the compressor is ok?the condenser pumps i.e the two pumps the smaller pump is hot as it should be but the larger pump is hot when im sure it should be cool, what could this signify?,could it be that i need my unit gassed up?if so how much will this cost?. Im i looking at a service and fluid change?Any suggestions would be helpful as im in the dark when it comes to air con units. E220 salon 95 plate. CHEERS .. e220man...
