Help! COMAND not working
jerrytlr
My COMAND has just stopped working - symptoms are it switches on but gets 'stuck' on the Mercedes Benz logo startup screen. Tried switching on and off a few times, ignition on and off a few times, disconnected phone interface.... but all to no avail.
Any suggestions/assistance gratefully received - eg is there a 'reboot' facility of any kind??
Cheers
Jerry
I would try pulling out the Comand fuse for 5 mins, it could re set its self
stevolt
Manchester UK
C320 Sport Estate
My C320CDI W203 Estate has the same problem - splash screen for a few seconds, and then turns off.
The problem started immediately after I tried starting the car cold without letting the glo-plugs do their job first. Then, after starting it properly, the Comand wouldn't work.
I did this before a while back and the same thing happened to the Comand but then it came back on after switching everything off and re-starting. This time it won't!
Where would the COMAND fuse be on my car, and is there any other suggestion/s?
