Dr Somashekar v
- May 3, 2020
- 2010 w204 c250 cdi
Hello all,
I own a 2010 w204 c250 cdi in india and have done about 146000 km . Around 6k km ago I had a problem with low coolant level and water pump , thermostat , fuel rail was changed . There was no problem until recently when I found low coolant warning again , 500 ml of water was used to refuel the reavoir upto the optimal level .on further driving 1000km later same problem occured . I examined the coolant system , no visible leak was seen . There was no oil mixture seen in coolant tank nor was a thick filament seen on the reservoir cap . On inspection of the dipstick there was no signs of coolant mix . There seems to be collection of a fluid on top of the engine block which I've marked using the red arrows . There has been no increase in the running temp of the car. I've will post picture of finding on inspection of the car . I humbly request the memebers of this forum to provide their valuable input as to culprit and the subsequent action to be taken actions to be taken . Thank you in advance !
