stivesvelo
- Mar 19, 2007
- Location
- CAMBS
- Website
- www.orientalexpression.co.uk
- S210 E320 cdi estate
I've been replacing a fuel line having made a temporary repair just over a week ago & am struggling to fix the lower run which is hidden from view below the fuel pump. This is a result of having cracked it whilst changing the thermostat which was going to be an hour of two of work & quicker than taking it into the garage!
This is not as straighforward as it might look as everything is squeezed in very tightly & it's proving to be a real struggle, I wish I'd never started & just taken it to the dealer.
Having no manual & using the Russian exploded views I'm sort of working in the dark as I can't see what's below.
I'll try to attach some photos showing the problem, hopefully someone will have some ideas. The main problem is access & I'm wondering if the radiator swivels forward to give access to belts etc for maintainance (as my transporter van did), or do I need to carry out some major dismantling??
