Help- ML270 cdi - seals on gas cooler connector
ml270n
Hi, AFter expierencing limp mode on the 270cdi, I replace the MAF(thanks to info on this forum) which solved the problem but 2 days later there was air sound coming from the gas cooler pipe which connects to the EGR (or gas mixer chamber). After searching on the net I foung a diagram which show a seal on the intermediat pipe connector. I don't see any threads and not sure to split the pipe from the EGR. IS this a push fit which needs special tools or could a beginer DIY replace the seal.
Thanks for the help.
kebo57
Lanc's
ml270
Hi is not the best picture to ilustrate your problem but is this the pipe that you talk about see pic + circled item if so yes you could remove the egr valve to replace what you call the intermediat pipe connector
Kevin
