Help needed in locating an R129 radiator
Sdemon
500sl
Unfortunately my radiator on my r129 500sl has a hairline crack at the plastic top housing. Tried searching for one but I can’t seem to find any and mercedes are not looking that promising either.
Does anyone know where I could source one from? Iv tried various radiator manufacturers and they are unable to supply one.
Or is there a possibility for this to be refurbed at all?
The original part number is 1295000103
Photo attached
Based in uk
Thanks in advance
Sdemon
500sl
Lostkiwi thanks for replying.
When I go to that website the only ones that come up are unfortunately out of stock. The link you posted, is it a different model number?
mioba
Nottingham and Köln
Carefully run a hot soldering iron in the hairline crack.
It rarley works as the melt is only on the surface and the crack is much deeper, so any heat expansion usually forces the melt open again
What are the first 6 numbers of your vin?
It will be 129xxx
Sdemon
500sl
It’s 129 067
Sdemon
500sl
Thanks Ray
On that website it mentions 2 versions:
1295000103 kuehler
129500010364 kuehler
Does anyone know what the difference is?
rayhennig
1991 300CE-24 Sportline
Thanks Ray
1295000103 kuehler
Sorry, no. Damned good question though.
R
Misterdog
A160 (W169) 2010
Have a look here.?
