Help Needed Please With Brakes On 380 Sec(1985)
christopher.cross
Please can any member advise me on a brakes problem with my 1985 sec 380coupe? The brakes are fine and pull up very well nice and straight but just when the car comes to almost a stop the pedal seems to jump back up a bit and shudders? I have new pads fitted and the pistons in thy calipers seem to move freely. Could the problem be related to the ABS system maybe a sensor with luck??? Any ideas would be much appreciated.
Many Thanks Chris:confused:
Are the disc contaminated was it like it before the new pads
panason1c
Somerset, UK
"pedal seems to jump back up a bit and shudders"
Sounds ABS related to me, as if the abs pump is kicking in as you come to a standstill for some reason.........
Take out the fuse that controls the abs system to disable it and see if the problem is still there, if it is, try cleaning up the wheel sensors.
tromppost
South East
s320
I had a 420 SEC that did this after I had the disc changed. It was down to an upgrade needed to each of the front brakes. Some sort of cable or hose! Thought yours would of had it by know.
C
christopher.cross
Hi Malcolm.
No the old brake pads were in good condition with no visible contamination.I am thinking that the drivers side callipper is sticking slightly???The car did pass its MOT today with Zero problems but this slight judder on the brake pedal when the car stops is bugging me?
kind regards chris
C
christopher.cross
Hi Panasonic.
Yes great idear I will try that tommorrow and let you know.
Regards Chris
C
christopher.cross
HI Tromppost.
Thanks for the reply. The car actually has always had this slight shudder since I have had it but I was a little concerned cause it had its MOT today which I am hapopy to say it passed with no problems at all. however now I am determined to get this slight shudder sorted.
Regards Chris
C
christopher.cross
Hi again Panasonic.
Please can you tell me where to look for the ABS fuse? Is it likely to be a simple fuse or a relay?
Thanks Chris
I do not think its ABS related,, first I would clean the disc with spirit and the do a few very hard stops
star
Reading
Smart + others :)
sounds like abs to me, esp if the pedal kicks back, more like the control unit not getting a signal from one of the sensors, normall happens at parking speed/ and with slight steering imput. u can take fuse out of OVP relay, behind fire wall, centre of car in front of wipers? or test with meter to see if signal fails.
C
christopher.cross
Hi Star.
Very kind of you for your input. Have'nt had time today but will check it out next day or two. you could'nt tell me where abouts the ABS sensors are on the wheel??? kind regards Chris
colechelle
Resigned
two leads go to the hub, one will go to the brake pads the other into the hub itself, thats the abs sensor,
star
Reading
Smart + others :)
you can get to them under the bonnet, on either side therwill be a large male/female aerial plug, this is the connector you need to test from, make sure you test the right end. :). the rear abs sensor connects under the rear seat but is a normal 2 pin job.
GEORGEROV
Morayshire
When an abs wheel sensor is on its way out it often starts off as an occassional vibration at the pedal just when coming to a stop. The abs light wont come on for this to happen . Can go on like this for long enough before it eventually fails (open circuit) and abs light comes on.
