For years now, my 2005 SL500, which has just 58k miles on it has had a curious tapping from the front end, probably under the bonnet, rather than at the wheels. Performance is normal, the noise hasn't get any worse, but the noise is mildly irritating, and so I am wondering what the cause may be. The sound is a light slightly hollow sounding tap, and manifests as follows:
1. When first started with the engine cold, there is no noise over the rev range.
2. When in neutral, there is no noise over the rev range, whether the engine is hot or cold.
3. The noise is only present after about 1/2 mile of driving i.e. as things warm up.
4. The noise isn't present on light acceleration but starts to appear at around 1400 rpm.
5. The noise disappears at revs above 2000 rpm.
6. The noise is not present at any revs on the overrun.
7. The noise seems to be at about half engine speed and the tapping follows the revs of the engine not the speed of the car, as gear changes occur.
Anybody got any ideas? All suggestions gratefully received.
