Help needed with abs/esp
Trev1964
Lydney
CLS 250 cdi estate 2013
Have the abs/esp lights on and traction control plus tyre pressure monitor fault.
Scanned codes and got 44a800.
Says also L6/3, left rear axle rpm sensor has a mechanical fault.
I have replaced the abs sensor on that wheel today. Reset the codes and it hasn't cured it.
Car is a 2011 E350 cdi coupe. C207 model.
Any ideas folks? Reluctant to throw parts at it in a vain hope of curing it.
All input welcome. Thank you.
bertb1
C220 amp sport 2013
You may need star to reset
Trev1964
Trev1964
Lydney
I have the carsoft i980. It says it has cleared the codes and the lights go off. Come straight back on when you set off though.
bertb1
C220 amp sport 2013
Good Indy will sort it
Where are you ?
Trev1964
Trev1964
Lydney
Lydney. Not far from Bristol.
Trev1964
Trev1964
Lydney
Just thought to add that I checked live data on the sensors after fitting the new sensor and It reads the speed fine, as do all the others as well. So not a faulty new sensor. Wish I had thought to do that before ordering a new one.
Ardunto
vito 112 2.2 diesel
Hello, People. Got a vito with the eps, brake, anti skid staying on on my Vito 638 07 plate. Is it possible to clean the abs rings. The next question is how to get to them front and rear. Any info gratefully received :}
Trev1964
Trev1964
Lydney
Think I'm gonna throw it at an indy to sort if I'm honest. Messaged Steve on here, see what he thinks.
Have a few other bits need doing and may just bite the bullet and get the lot sorted. See what he thinks when he replies.
Ardunto
vito 112 2.2 diesel
Also, if the lights acually go out. There is no electrics on it. I.E no indicators horn no nothing
