help no spark
daz250
norwich
1995 e280 estate e300td 1998 estate, 2004 aventgaurde estate
Help. Just replaced head gasket on w124 e280, the car is all back together, went to start but it wouldnt,checked the spark plugs but there was no sparks. could it be the coil back? any suggestions would be great help. thankyou.daz
Have you got the cable back onto the crankshaft sensor
D
daz250
norwich
crakshaft sensor
Dont mean to sound thick but where abouts is the crankshaft sensor? The only sensor we took off was the camshaft sensor, which we put back on. Apart from the crankshaft sensor, would there be any other reason for it not too spark? Cheers Daz.
D
daz250
norwich
Thanks for the reply malcolm, but the crankshaft sensor is intact. if you have anymore suggestions it will be appreciated. thankyou daz
kth286
E320 Coupe 95
daz250
did you check every plug for spark ??? You need to.
Each of three coils feed two plugs each ie two cylinders. Only one coil or all coils may have blown.
The problem is the engine wiring loom on these cars. The insulation degrades. Has yours been renewed or is it original ????
If it is original then you have probably broken the insulation on the coil feed wires which are inside the thick rubber strapping on top of the head (under the top cover)
You cannot see the individual wires until you have trimmed back the outer black covering.
The coil feed wires will have shorted and blown (only) the coil or coils if you are lucky.
If you are unlucky it will also have blown the coil driver circiuts inside the main engine ECU.
A new one is approx £1,000 and a new engine wiring harness is about £650.
You may be able to get the ECU repaired.
In your view Kieth would you say as this was a head gasket job to start with the the fault could be more the wiring as its all been disturbed,, and also bearing in mind that the harness if faulty can damage other things
D
daz250
norwich
Thankyou for the replys. there is no spark to any of the plugs. the car has done 173,000 miles and i dont know whether the harness has been replaced but it looks in very good order. can i test the coils with a vault meter. daz
Sorry to be a little blank on this.
forget the coils as one would work and you cant test them with any meter to get a sensible reading
What are the first 6 vin numbers 124 --- the next 3
D
daz250
norwich
they are 124088
killingtime88
Wolverhampton
Is it running now
Hi there I have the same motor 1995 e280 estate if you are still struggling I am willing to measure voltages etc on mine to compare and try and see whats going wrong with yours
Btw if you haven't got a blinker for testing the fault codes i can knock one up and send it down to you FOC ive got enough junk here to make about 20 of them.You will just need the banana plugs for the end as i have run out of them.
Regards Paul
D
daz250
norwich
hi paul thankyou very much for the offer, but i am having the coils tested tomorrow, and the wiring loom has been checked and is in very good condition so hopefully i will know the results tomorrow. Thankyou daren
killingtime88
Wolverhampton
Ok Daren good luck with that the offers still there for the blinker, i made one up earlier tonight they are very useful in helping with diagnosis.
Paul.
