Help on sd cards for music
jake.e250
E class 250 2014 coupe
Hi. I’m completely new to all this so excuse the potential stupid questions.
I’m looking to find what sd card I can use for music in my 2014 e class. It’s got an sd card slot in the dashboard and has the option to use it for music on the audio menu.
I’d like to know the sd capacity I can use and what kind I need and what format it has to be in.
jake.e250
  • #2
Trying to find out what type of sd card I need to use for music/audio in my 2014 e class. The capacity the format the type etc. it has an sd card slot in the dashboard. Any help would be appreciated
Larkone
NW Essex
C219 CLS 320CDI 2008
Usually format as FAT and file format MP3. I have used 4 and 8GB cards without issue. Your manual for your unidentified sound system will tell you exactly
jake.e250
Thanks. 8GB will hold a load of music won’t it?
Srdl
Hampshire
GLC43 AMG 2018 (X253)
Different models have different standards as Mercedes technology has developed. My 2010 car was much more fussy than my 2018 one.
If it helps, the following is from my electronic handbook (Mercedes Guides app):
The multimedia system supports the following memory cards:
  • SD cards ( Secure Digital)
  • SDHC cards ( Secure Digital High Capacity)
  • SDXC cards ( Secure Digital e Xtended Capacity
Permissible file systems
  • ISO 9660/Joliet standard for CDs
  • UDF for video DVDs
  • FAT16, FAT32, exFAT and NTFS for SD card and USB storage media
NJS5
Catherington, Hampshire.
2011 R230 SL350, 2016 Discovery 4 Landmark, 1973 MG B GT V8, 1959 MGA roadster.
Thanks Steve
Slightly off-topic I wonder if anyone knows how large an SDxx card can I use to store vast quantities of music for my SL R230.
TIA
NJSS
Larkone
NW Essex
Thanks Steve
TIA
NJSS
You need to look up what unit you have and check the manual for the max SD card size. Then it will depend on the format of the music - usually MP3 - and the bit rate. Use the calculator I posted to find out.
