Help please 2003 E200 Kompressor Emissions problem
andrewb
Hi All, just wondering if anyone can help me with my problem, My 2003 E200 1.8 Kompressor has failed its emissions test. Engine management light has been on for a few weeks before the test, the fault codes pointed to faulty lambda sensors, I ordeded two new lambda sensors from mercedes and fitted them but after a few miles engine light came on, My mechanic advised me to change the catalytic convertor which I did but fault code still reading the same, Dont want to carry it to a Mercedes main dealer as they seem very expensive, Any Help or advice is very much appreciated. Thanks, Andrew.:)
A
andy@pcd-ltd
Hi
What are the fault coodes that you are getting on the car.
What area are you in
124coupe
You have the process backwards - you are spending money on "downstream" components being killed by a problem in air/fuel/ignition - what were the codes?
Any driveablility problems?
errrr, fault codes and mot emissions fail details please for me too!! was it co levels or lambda value?
I think O2 sensor
he has changed them malcolm.
A
andrewb
Hi, thanks for all the replies, I,m in Dublin, Ireland, At low idle CO was 3.21, at high idle lambda was 0.901 and CO was 3.49, I cant seem to find the fault codes, I will put them up when I get them, cheers
hello.
those figures tell us that your engine is running extremely rich. possibly the cat would work ok if it was not so rich.
causes could be many and varied, but maf sensor is strong possibility. more unusual faults could be high fuel pressure or poor contacts at the (new) upstream lambda probe.
basically loads of possible problems - we need to plug you in dear sir.
A
andrewb
Thanks for your suggestions Alexander Patient. I'll get it plugged in again on Monday to see what comes up.
pay attention to all the live data values - o2 sensor, maf and self adaptation short term and adopted long term values particularly.
bouncer
lancashire
C200k w203
Dont forget the EVAP canister purge system it could be allowing petrol vapour into the intake system.
Def running rich
sTeVe
A
andrewb
Hi all, got this problem sorted eventually, some vacuum pipes at the back of the engine were damaged causing the air intake to be all messed up, small enough problem in the end, just tricky to find, Thanks for all your advice.
k sidaway
2006 mercedes c class c200 kompresser w203
I have anew lambda sensor on my c200 compressor w203 but emissions are still very high why ?
Dean Fletcher
Penrith, Cumbria
Mercedes E400
Hi k sideway I'd suggest starting a new thread and try and include as much detail as possible. Loads of very knowledgeable people on here who will help.
